Finished the trim system. Powered it all up and discovered that when the trim is actuated it puts out enough RF that the Dynon can't talk over the DSAB. Short burst of trim would cause everything to fail except the EFIS. After trouble shooting I discovered it was in the relay. I tried several locations even outside the aircraft aft of the tail. As long as the relay is in the circuit it causes the dynons to stop talking when trimming. Everything comes back within 30 seconds but thats not good enough. I even tried it with all of the wires outside of the aircraft with the same results. I rewired the left grip to switch the power for the trim and everything works fine. My Plan now is to rewire the right grip and add a transfer switch as they can't run in parallel using this method. I guess the advantage to it is if a switch fails I can transfer to the other system.
