Finished fabricating the center fuselage longerons. I thought that the second one would go faster than the first but it took about the same time. Placed the longerons in posiition then measured from the table to bottom of longeron tip and found a 1/4 inch difference. Checked them again and found that I still had a slight bow in the left longeron. I worked it until it was flat then got the same measurments.
