RANDY'S WEB SITE
Date:  3-3-2009
Number of Hours:  3.00
Brief Description:  Side stiffeners
Worked on the right side stiffeners. Spent a lot of time to make sure they would line up with the skins. Used a piece of sheet metal to locate the front prior to transfer drilling. Fabbed up the required shims and transfer drilled.
Used a piece of sheet metal to locate stiffener
Had to make several shims
