Deburred and primed the rest of the skins. Borrowed a debursit tool from a friend works great on the skins, I guess I will have to get one. Clecoed on the rest of the skins and riveted the top side. I used a piece of PVC in the nose of the leading edge to round the nose a little , It worked pretty good but need to be gentle so as not to leave a crease. I noticed that Rans has put a flange on the top pieces of their skins so I flanged the trailing edge of the leading edeges. The rivet schedule for the spar doesn't add up but I think I got it right. I needed a cleco in every hole in the spar to keep the rivets from binding when putting them in. I also left the hinges clecoed I am going to wait till I have the servo tab built befor I rivet them.
