Turned the wing over and built some blocks with stops to hold it in place . Checked it by pulling some strings. Made marks on the upper and lower skins as per the manual then removed plastic from the right wing leading edge. Clecoed and taped skin in place then taped ribs in place. Drilled to spar and ribs to 40.
