Riveted gussets to bulkhead #5 and front and rear longerons . Riveted center section skins to longeron, Riveted top of tailcone skins to bulkhead #5. Counter sunk and riveted gusset to longeron. I have been working on a divider that would hide the choke and other cables, but have pretty much decided that leaving it and the center support out like the production plane would give much better access under the panel. Problem is Carlene likes it. I will have to order a new sub panel if I go that way since I don't want any cables going through the panel.
