Brief Description: Joined Tailcone and Center fuselage
Removed the #5 bulkhead and riveted stringers as required replaced and riveted bellcrank then joined the tailcone and center fuselage. Clecoed the top and sides then slid fuselage off the table and supported tailcone with a saw horse allowing me to cleco the bottom. Connected the elevator push pull tube to the bellcrank and control coulmn, then adjusted the tube and stops where they hit before the servo stops. Riveted fuselage on the outside.
