Primed most of the tailcone parts. Found a a couple in the pile that had not been deburred so I deburred them and the bottom skin. After removing the plastic from the bottom skin outside surface I discovered quite a bit of oxidation on the skin. Spent about an hour with scotchbrite pads to remove it all.
