Finished up the sub panel. Cut and installed mag switch, alert volume pot, intercom, elt control, trim indicator and hobbs meter. I wanted the mag switch about an inch further left than it is but I forgot about the supports that go there . I had already drilled the main switches so I had to place the mag switch closer to them than I wanted. I may get a new part and redo it. I had planed on putting in emergency mike and phone plugs to bypass the intercom if it failed. Then I discovered that the new PM1000 II has a fail safe mode so I left them out.
