Brief Description: Seat Supports and baggage floor
Finished riveting belly skin where required except for antenna backplate as it was bent up backwards. I will have to make one or get rans to send me a new one. Started on the floor skins. The instructions are poor in this aera. Took an hour to figure out that my kit has been revised in this aera but the plans have not. Mainly there is no middle seatbelt attachments. They now attach to the flap weldment. I think that is addressed on rans clan but I had to figure it out myself. I decided to follow my own plans on the floors and mocked them all up. Now I can see better what has to be transfer drilled and how the nutplates are arranged. Drilled some of the nutplates and used a unibit for final size. I see that the side skins will have to be clecoed on to transfer drill some of the holes in the right place. LATE NOTE: My antenna backing plate is not bent up backwards, I installed the the belly skin with the ant hole on the right side and it should be on the left. None of the drawings show the hole and nothing is in the text. I am going to bend up a new plate for the right side. I may put the other one in the left side in case I ever want another antenna.
