Spent some time cutting and pasting panel instruments. Really like the Dynon stuff. Put the panel up to the panel frame then put a mark on the panel that gives me the clear space behind the panel. I will have to notch the lower frame of the panel to use this center stack. An SL70 transponder would fit without modification. Also looking at the Hi Res Dynon comming out this year but don't like the idea of having to update two different Databases. Right now I am 99% sure this is the way I am going to go.
