Brief Description: Rear Spar Bulkhead Support Angle
Fabricated and drilled the Rear Spar Support angles. The manual tells you to fabricate the angles but doesn't give a part number or size of the stock. I am not sure where I found it but the stock is PN KAAC0044-12. There is a drawing for the left you have to figure out the right. I built the left and figured out where it went then carefully made the right.
