Transfered lines to skin then taped one side of leading edge to spar. Then drilled to 40 and clecoed. Removed leading edge skins and worked the bend for a better fit over ribs. Reinstalled taped reverse side then drilled to 40 and clecoed. Aligned ribs and began to drill.
