Installed a landing light. I bought a Kunselman 3 inch round light but I didn't really have enough room in the cowling to install it so I bought a Halogen driving light from pep boys. I got a pirce of tubing the size of the light and cut an angle in it that would position the light horizontal then used it for a template. cut a hole and fiberglassed a tube to hold the light. Cut the tube to size and installed the light. When I was happy I drilled for the bolt that holdes it in and glassed off the back of the tube. Wired it in and turned it on. It draws 5 amps, while the LED would have pulled probably 3 amps.
