Did some more fiberglass work on the cooling ducts. Calibrated the left and right fuel tanks. The right is ok reading full at 11 gal and empty at 1 gal. I will have to rework the left sending unit as it reads full at 6.8 gal and empty at 1 gal. Tanks leak checked ok. Checked boost pump which works ok but it overpowers the float in the carb. Fuel flow checks out ok but the fuel pressure reads zero. I may have to bleed the line to it. Added camlocks to the oil acess door.
