Drilled a pilot hole for the right fuel line, I will open it up and install a gromet after the wings come back off. Drilled a hole for the left wing OAT and fuel quanity. Installed a connector. Found a location for the left fuel line but I'm going to drill it after the wings come off. Tested the OAT which I chose to wire into the EMS instead of the EFIS and I'm not happy yet. It works fine on the EMS but isn't transfering properly to the EFIS. If I can't figure it out I'm going to order the probe that hooks into the EFIS.
Pitot,static,fuel quanity and fuel line.
OAT and fuel quanity, fuel line will have to go over the servo.
