Updated all the Dynons to 5.4 operating system. Installed pitot and static lines from the dynon to the acess hole in the right side of fuselage. Re tied all the wire bundles and tied the serial ports where they can be accesed. Removed interior panels and trimmed a little more. Built up the aileron push tubes and installed them. I will probably have to relocate my fuel lines standoffs as the aileron tubes go through the same hole and I suspect clearance will be a problem. Removed plastic from top cowl. Deburred all the holes and polished the edges. Primed the underside then painted where it will be exposed in the cabin. Re installed acess panels in the cabin floors.
