Found issues with the location of my power points and map lights so I moved on to fuel lines. Removed a 45 and 90 degree fittings and replaced them with straight fittings. Routed lines and clamped with nylon clamps. Built stand offs where lines exited the fuselage using tubing a 3/16 bolt and an adel clamp to secure.
NOTE: I removed the fuel lines from the location in picture #1. There isn't enough room for the aileron push pull tubes and the fuel lines. I have the wings attached now and will make a log entry when I find a alternate location.
Made a stand off for fuel lines
used nylon clamps on floor
I have modified my fuel selector so the fittings that Rans calls for don't work
