Hooked up the voltage regulator to the alternator, battery plus and minus and buss load. Wired tach into altenator wire. Made up fuel lines and connected from firewall to pump to carb and pressure sensor. Made a number 4 ground to go from the battery to the starter per jabiru. Started to tie up bundels of wires.
