RANDY'S WEB SITE
S-19
Vents and prop extension
Riveted NACA ducts in place. Built a fixture to install the prop extension. Removed factory extension. Cleaned bolts and ran a tap through the bolt holes to remove old loctite. Installed prop extension using loctite 620.
S-19 Home
1515
Aft fuselage
Aft Fuselage
Center Fuselage
Construction Tips
Cowling
Fuel tanks
172
FWD Fuselage
HorizontalStabilizer
Inspections
Instrument Panel
Phase I flight test
Vertical Stabilizer
Wheel Pants
326
Workshop
