Decided to mount and rig the stabilator so I could finish up the baggage compartment floors. Adjusting the forward push pull tube looks impossible with the floors in. The instructions never tell you to ream the support brackets so I had to drill out the balance bar support to get enough room to ream the stab brackets. Reamed brackets and riveted balance bracket back in place. Mounted the staib and rigged per manual. Found the grommet strips I ordered a while back and placed in the spar pass throughs.
