After building a stop for stick full aft and to the left I discovered that the pushrod rubbed when in the full forward and full right position. I removed the stop that I made and tried serveral others and finally came up with a solution. I've ordered the longer arm but wanted to see if I could get this to work. Rigged pushrod and riveted servo into position.
