RANDY'S WEB SITE
Date:  6-2-2010
Number of Hours:  4.00
Brief Description:  Aileron servo
I built a aileron servo bracket.Bolted servo into bracket and clecoed in place. Set aileron control stops and discovered that with the 30 degree throw left and right that the servo arm is too short. I was going to order the long arm but discovered that if I limited the throw to 27.5 degrees I could use the short arm. If I need more that that when I rig the ailerons I will have to go with the long servo arm. With the stick all the way back and all the way to the left the bellcrank could be forced overcenter although the airframe would have to bend to do this but I built a stop anyway.
