RANDY'S WEB SITE
Date:  5-22-2010
Brief Description:  Air Box
The air box I got from Jabiru was open on the back side, I guess it's supposed to go on a flat surface. Since the S19 firewall has bumps in it I had to make a back cover. I thought about fiberglass but decided to cut a piece of aluimum and rivet it on. Sealed it with silicone and riveted together. Located it on the fire wall then drilled 4 holes for mounting. Located the carb heat cable location and drilled. Installed box with 2 washers under each bolt for clearance on firewall. Routed carb heat cable.
Airbox with cool and heated air supply
Sealed back of box
Sealed back of box
In place on firewall
