Brief Description: Installed vertical stab and rudder
Started working on the brake system and realized that I really couldn't run the brake lines until I had the rudder installed to see how much travel I was going to have. Installed vertical stabilizer and rudder. Rigged rudder, then made notes as how much travel the rudder pedals had. Removed rudder and stab as I will have to trim the bottom of the stab skin to fit properly in place with the gasked installed. I also wanted to run aluimum tube from the parking brake valve to a bulkhead fitting then down the strut. I put an axle to the strut and decided that I would need a felexible line to the caliper. I don't see a clean way to do that so I'll probably stick with the nylon tube.
