Rearangede the hangar then removed cowl and side skins from fuselage. Removed the sub panel which I am replacing so I can add the controls which would have been in the center consul. Mocked up the retrofit with the throttle cable. Connected the rudder springs and fit the nose wheel and engine mount. Played with the air box a little. It is open in the back and is desinged to go on a flat surface. I will have to make something to close it up and shim it where it attaches to the firewall.
