Drilled leading edge and tip skins to 30 then dissasembled. Deburred frame. Installed bellcranks and push tubes. Discovered that I don't have enough bushing material for the rod ends.
Drilled to 30
Deburred frame
This is all I had to remove from the ribs to keep from dimpling the skins
