Brief Description: Bolt the bearing to the rear spar assembly
This didn't go well :) The first time I used the torque wrench I had no idea what the "click" felt like. I over-torqued every bolt.
So, off to El Cajon Aircraft Supply and got more bolts, nuts and washers. I also spoke to my local EAA Tech Counselor and he told me about Nord-Lock washers. I ordered them as well, and longer AN bolts so I can use them throughout the build.
