Adjusted stabilator cable tension to 40 lbs. (removal of F-1227 floor panel reduces tension to 25 lbs.!)
Installed lap belt and shoulder belt attachments.
Had a problem with the crotch attachments. The holes on the support brackets are too large, requiring internal washers for proper installation. Called Vans and they agree with the solution.
