Fabricated the F1270B terminal blocks. Had some trouble with the AB3-4 rivets pulling through. I called Vans and found out that they are going to replace this terminal block with a connector, This will be a welcome improvement.
Prepared adn istalled the F-1204Y conduit.
Ran the antenna wires for the transonder and the communication radios.
Ran the RS279-374 cable for the ELT.
Installed the rod ends on the flapperons with locktite.
