While waiting for paint equipment, training, and booth preparation, continued ahead to the fuel system.
Made tank to fuel pump line assembly.
Drilled 5/16" the F-1276C system blocks.
Rivetted the fuel valve bracket to the bottom skin.
Match drilled and installed the fuel pump assembly to the bottom skin.
Installed the fuel pump to tank and the fuel pump to valve lines. Will make pressure test setup to test prior to continuing. It is easier to fix now than later if there is a leak.
