Found out had installed the wrong connector on the right wing! Removed pins from right wing connector. While trying to remove pins on right fuselage side, broke the removal tool! A call to Vans revealed that the toos used is the wrong one. Fabricated a pin removal tool.
Ordered a new set of connectors, pins, and mountign screws.
