Patricks Web Site
Date:  12-25-2012
Manual Reference:  6
Brief Description:  Finished wiring and Fuel tank sealed
Finished wiring the wings this morning. I used clear plastic tubing for the left wing but discovered that the right wing did not have gromets big enough for the tubing..... So I just ran the wiring in the right wing through the gromets that were already installed in the quick build wing. Keep it simple stupid. I should probably have done the same thing with the left wing and still may before riveting the bottom skin.
Also sealed the left and right fuel tank with the supplied cork seal and gasket seal. It turned out very nice, even nicer if it passes the fuel tank pressure test. Merry Christmas Vans
stall warning joining strobe and nav lights
Right Tank
Right Tank
Left Tank
Left Tank
