See spiral-bound build log - lay out pitot static and pressure system and order parts start the fixed cross for the VHF antenna ground plane flaperons need a 1 1/8" linear actuator research Rony brackets and order from Leading Edge Airfoils Get the VHF antenna permanently installed 17:00 test: very noisy, VOX intercom very bad - this is with the Bose headset order vinyl tubing to run the pitot line from top forward through the left front down tube - keep it concealed install top root tube door frame re-install ELT antenna further forward to get cable clearance past both middle posts start to wire up the ELT remote switch soldered connections on the sub-D connectors: train wreck - this is not airworthy - stop here and order better connectors.
