Phills Web Site
Date:  6-21-2019
Number of Hours:  3.00
Brief Description:  Fix fuel weep leak at tank strainer threaded conne
Fix fuel weep leak at tank strainer threaded connection
Re-route fuel line: 90 degree out of tank to forward loop back to gascolator.
Good clamp hose to frame just downstream of tank 90 - try to reduce/eliminate vibration and strain on the tank threads. Don't need metal failure here.
Refill with 7 gallons. Leak test passes.
