back on VHF harness: study closer: can NOT use 8-conductor wire on hand: MIC and audio shields go to different grounds, so must be in separate cables. Order 22-3 shielded, crimp pins, etc. and stop on this. Leave the factory harness intact for reference and backup. Research, study, study, study.
Finish ELT wiring. Download test procedures. Need VHF on its feet for some of the tests. Put the shipping plug with the kill shunt in it back on the ELT so no accidental triggers.
start running flaperon linear actuator wiring install GRT coolant temp sensor on front tray and test - looks good - default temp indicator on home page, use as air temp and make that slot useful
