Phills Web Site
Date:  6-30-2019
Number of Hours:  8.00
Brief Description:  avionics install
See spiral-bound build log - lay out pitot static and pressure system and order parts
start the fixed cross for the VHF antenna ground plane
flaperons need a 1 1/8" linear actuator
research Rony brackets and order from Leading Edge Airfoils
Get the VHF antenna permanently installed
17:00 test: very noisy, VOX intercom very bad - this is with the Bose headset
order vinyl tubing to run the pitot line from top forward through the left front down tube - keep it concealed
install top root tube door frame
re-install ELT antenna further forward to get cable clearance past both middle posts
start to wire up the ELT remote switch
soldered connections on the sub-D connectors: train wreck - this is not airworthy - stop here and order better connectors.
