Brief Description: seat belts, flaperon mixer, ELT, rear seat back
Install shoulder and lap seat belts front and back. Do not like having to cut a rectangular slot through the sheet metal for the front shoulder straps.
Next bag of parts: Install flaperon mixer crank and rod ends. Order 6061-T6 tubing for the middle section.
Mount the ELT: 6 bolts to root tube above rear seat. Start running wiring for remote switch. Need research on DB9 and DB15 pin-outs before soldering these up.
Dig out and study Challenger 101 assembly instructions for root tube door mount frame. Need to rebuild longer to fit around ELT mount and front seat shoulder harness bracket. Order 1/2" tubing for the rebuild.
