Brief Description: New prop blades; wrap up suspension and brakes
So far this week:
Pretensioned the suspension springs by 3/4" to take the splay out of it. They are sitting on the stops with all equipment aboard and full fuel, no wings, nobody aboard. Looks good so far.
Mount the rear brake actuator and do the final routing on the brake lines. Looks good so far.
Four new blades received from IvoProp. Installed 3. These are 97.5 gram blades. Two of them have unreadable stamped-in numbers. Called IvoProp today to ask for the serial numbers on these blades. The stamped numbers are NOT serial numbers. They are date of manufacture. Should show 19 for the year, then the month number, then "R", then the day number. Ran the new prop on a 10-minute taxi test on Wednesday after installing. Looks good so far.
Bolted in the rear seat and the rear lower cross bar.
Policed up some wiring. Starting in on the final installation for the ELT, ADS-B encoder and GPS antenna, and routing the VHF radio connections.
