Magnificent Adventure
Date:  9-28-2012
Number of Hours:  9.00
Manual Reference:  Section 9
Brief Description:  Battery box and solenoids
Installed Master and Starter relays on Firewall. I also assembled the PC680 Battery Box and temporarily installed it on the Firewall. I say temporarily because several items need to be installed on the firewall before the center cover is riveted in. This hole in the center of the firewall will be used many times in gaining access for riveting and intalling items. The center section will probably be installed at the same time as the engine mount.
Battery Box and solenoids
Center hole in firewall
