Magnificent Adventure
Date:  1-23-2014
Number of Hours:  4.00
Manual Reference:  Section 7
Brief Description:  Aileron fitting
I had to replace two rivets on each inboard aileron mounting bracket on the wing - both sides. I incorrectly had the flush end of the rivets on the inboard side of the brackets, not the outboard side. This created a slight rubbing on the aileron bracket attached to the aileron.
Installed the small aileron pushrods and checked for movement. I am showing approximately 17 degrees down and 28 and 32 degrees up movement. Final adjustments to be made after wing installation.
