Magnificent Adventure
Date:  1-3-2014
Number of Hours:  5.00
Brief Description:  Remove wing tips and wiring work
Removed the wing tips today. Left wing tip will need to cut and re-glassed to fit correctly. Also pre-wired for future ADSB-out that will be connected to Dynon Serial Port #3. Installed fuel pump warning light below panel switch. Started process of securing wiring.
Also have prewired and installed tubing in left wing for future heated pitot/AOA.
