Magnificent Adventure
Date:  8-23-2011
Number of Hours:  5.00
Manual Reference:  Section 7
Brief Description:  Aileron work
Finished the right wing aileron mounting brackets and mounted the aileron. I then set the neutral position as instructed, adjusted the aileron pushrod and locked in position. Then I removed the aileron and push rod, after marking the pushrod with an "R". Both were set aside until some time in the distant future.
Installed the aileron brackets on the left wing after match drilling, deburring and countersinking where necessary. Next session will be mounting and adjusting the left aileron.
