I received my Builder's Airman's Certificate from Brian Wilson this morning.
Paul and I looked into the radio transmitting probem and found that a small screw was impeding the insertion of the audio panel into its sleeve. removed two screws and the audio panel appeared to be working fine; both transmitting and receiving.
We also checked out the #3 EGT connections and recrimped a couple of terminals. It also seems to be working correctly.
