Magnificent Adventure
Date:  4-3-2014
Number of Hours:  6.00
Manual Reference:  Section 8
Brief Description:  Torque check
Checked torque settings inside wing and fuselage. Checked fuel lines and re-tested torque on all connections. Applied torque paint to all.
I also painted the inside of the bottom cowl white for heat reflextion. I will be adding some heat reflecting tape where needed at hot spot areas.
