Pisandros Web Site
Date:  8-9-2015
Number of Hours:  2.50
Brief Description:  Wing tips
Started the work on the wing tips today. Thi stask consist of removing the wing from the Jig, and setting up wing rib 11, conector angle, spar attach agle, and the tip. A hole wa drilled to fit the grummet where the wire will come through to the possition light.
Grummet
Grummet
Angle bracket
Angle bracket
Rib fitted
Rib fitted
