Ryan and I drove the Lower Front Spar rivets today through the apperture made by removing the bottom rib. At the end I replaced it. This is not called out in the instructions, but I feel should be done to provide as much support when the clecos are removed to fdacilitate access to the Upper Front Spar rivets.
