I quickly completed the Rudder Stop parts today. They are final drilled to #30 which is pretty easy.
I am a bit concerned about the fact that a tiny chip of paint came out of the hinge bracket when I final drilled. I will get some touch up from Vans.
At this stage I am stopping work on the VS and moving to the rudder. The reason for this is that I want to make sure that I do larger batches of parts when I prime due to all the set up and tear down activity associated with that process.
