Hamiltons RV Website
Date:  11-8-2012
Number of Hours:  0.50
Manual Reference:  Modifications
Brief Description:  Added Cable Attachment points for the VOR Antenna
I added the wire attachment points to the VS Middle and Bottom Inspar Ribs. Pretty simple, but I did them differently to the attachments on the front ribs. On the front ribs, I riveted the attachment to the other side of the rib. I believe that they were not oriented correctly. When placed this way, they extend nicely through the rib.
The front rib attachments are sufficient for the task, so I will not change them.
Bottom Inspar Rib with Cable Attachment
Middle Inspar Rib as well.
