Brief Description: Elevator trim servo installation
layout rivet lines for elevator trim servo drill servo attachments and cleko found centerpoint in trim channel flange and cut hole for control rod on trim tab horn, drilled pilot holes, alligned on centerline and drilled and cleko'd cut control rod to proper length
